I tried searching the forum and saw the last post on the subject was from 2016, AND that thread was closed to further discussion.
So, I'll broach the subject again...
I'm at the 32K mile mark on my 2013 GL1800 and have done most of the relatively easy maintenance:
1. Oil and Filter Change
2. Final Drive Fluid Change
3. Brake Fluid Change
4. Clutch Fluid Change
5. Radiator Coolant Change
6. Checked Crankcase Breather
7. Spark plugs and air cleaner were changed last year, so no need to mess with those for a while.
One item that "looks" easy in the Service Manual, (that's what I thought about the air cleaner change last year!) is Check Valve Clearance. However, there's mention of a special tool to "loosen cam chain tensioners" and the instructions send you to section 10-8, which is part of the cam shaft removal process. When I'm fuzzy on the instructions for any Goldwing procedure, I look for You-Tube video posts on the subject. In this case, I'm drawing a blank.
So, Has anyone out there done this inspection?
If so, are there any caveats you care to impart?
And/or can anyone steer me to a video on the subject?
Thanks in advance
Thanks in advance
