1 - 18 of 18 Posts
LOL ... yep, I'm a former HD owner. I guess we all make changes sooner or later.
I have just sold a HD Deluxe with a seat height (unladen) of 26". I would DEARLY love to get a Wing, and I have looked at two different dealers. The main concern to me is the seat height difference of 3". The Deluxe seemed to be a perfect fit for my leg length. That's a LOT of height difference. I am only 5'7" and have very short legs (28" inseam). However, I am a very experienced rider who has ridden off-and-on for 40 years.
Any advice other than taking a test ride? None of the dealers here will allow it.
Is the Wing difficult to handle ... moreso than any other large machine?
Welcome to the board. I can't believe if you are going to buy a $20k motorcycle from a dealer they would not even let you drive around the parking lot. That said, you can tell how well the Wing will fit just by sitting on one in the dealers showroom. If you can't reach the floor there then you would need to consider having some foam taken from the seat sides to give you more length or a custom seat to replace the stock. Beware though if you get a Wing with heated seats a replacement will be expensive. I have a 29" inseam and can reach the ground without too much of a problem. Some guys have purchased boots with a 4" lift which helps them reach the ground better.
As far as handling, the Wing is one of the smothest handling bikes for it's size. Very nimble with lots of power. The flat engine gives a very low center of gravity so the bike is not too top heavy. Good luck in your search.
Try another dealer, they should have demo bikes you can ride, The wing is very easy to handle once you get it rolling, and low speed handling like in a parking lot is great. As for the height there are several thing you can do You can do a seat mod. like this one
http://www.bikesolutionsllc.com/Small.htm
and someone now is making lowering block for the GL1800.
I'm Undertall as well =)
Hidalgo:
I am also 5'7" and have a 27.5-in inseam. I have been riding my Wing for a little over two years. Even with my boots, I can only get the balls of my feet on the ground and have never had a problem. Of course, I have to be careful that I don't "low center" myself at stops and drive edges. I have considered, but not implemented any plans to modify the seat/suspension. After two years of riding--half of it two-up--I don't believe I need the modifications; I do just fine.
You should be OK if you're an experienced pilot on heavy bikes. And I agree with the other respondants--the Wing is a smooth, low-center-of-gravity delight to ride. In fact, most believe it rides like a tourer, but performs like a sport bike. You'll especially appreciate that your ears won't be ringing from the tuned exhaust after an extended ride.
Find a dealer that has rental Wings; they usually will let you test ride one of them. If the dealer won't let you test ride, find another dealer.
Good Luck!
hello and welcome to GWOF hildalgo, are you looking at 1800 wings? i hear there is a lowering kit for it or you could go with a custom seat
Ditto on the seat, either full custom or alterations by an upholstery shop (reputable that is), just be cautious of the seat heaters. If there is a lowering kit for the 1800, you will likely end up with about the same lean angles and ground clearance you had with your HD, but on a much better handling bike. Many of the GL riders I have known over the years have inseam lengths like yours, and many didn't change anything. Definitley test-ride; I wouldn't buy anything without a test first. Any dealer that won't allow you to doesn't deserve your money or loyalty.
Remember that the lowering kit will make it very difficult to get the bike up on the center stand.
Well, have you decided? Just curious. I was where you are three years ago. I've been riding my Wing for about 2.5 of those and don't regret it. I agree a 27-in inseam is a challenge sometimes, but I've adapted pretty well.
The only times I've layed her down was in the driveway and garage (3 times) and at a tight dead end during a U-ey by being stupid--haven't done that in quite a while, though.
Let us know. :)
I was recently on a charity ride with lots of bikes. One guy on a 1500 was so short I thought he would be riding a scooter. But he could handle that big bike with no problem. He actually mounts the bike like a horse - never seen that before. So I wouldn't worry about it too much. Like I have said before on this forum, handling the GW is alot like other new things in life....you just got to take time to learn. The parking lot practice is a great idea. Lyndon
I am also 5'7" at 135 lbs. inseam is 28 inches. Been riding heavy bikes for a lot of years. Until the Goldwing I rode a Ultra Classic with a lowered seat. Now a 2010 Goldwing. At first I was very uncomfortable with it (due to the height of the seat). As a seasoned rider you know to keep your eyes up. That will make a big difference at stop signs and red lights.
I now have 6,000 miles on it and very comfortable with the Goldwing height.
I agree with renting 1 for a weekend or at least a day.
Once you get to moving (which will become easy as you ride it more) you will forget about the seat height.
I do wear boots with a thick sole.
I added a full sheep seat cover and before adding it I was good but after wards I have to lean forward so I can get my feet on the ground better. The cover really added comfort while riding but it raised the seat height slightly.
Kuryakyn is now offering a seat made by Mustang which lowers you 1 inch but it pushes you and you passenger back 1 inch.
just a thought
dd
I too am on the short side and unable to plant both feet flat on the ground when on my Wing... not even close. If I wear tennis shoes, it's worse but when I wear my heavier boots with thicker soles in the cooler season, I pick up an about an inch per side, which is helpful.
As long as you're not "teetering" from foot to foot and able to get adequate support with both feet touching the ground at the same time, thicker soles and a modified seat should do the trick. With the low center of gravity on my '08, I can lean the bike slightly to the side so one foot is flat on the ground without feeling like I'm losing it. Most of the Goldwing riders I ride with are on their toes at the red lights.
Also as mentioned, find a dealer that will allow test rides. Here in Vegas, nobody would budge but a small town dealer in Utah actually asked me if I wanted to test drive one and that was all it took! At that point, I would have taped 2X4s to my shoes if necessary to touch the ground. :D
I'm 67 yrs old, 5'7" with a 29" inseam. I had the same fear until I rode one. A week later I owned it. After having it for 3 weeks all my fears have gone away. I traded my Harley Heritage Softail for the Wing.........I am careful on uneven ground but it's not a problem at all.
if you have a "favorite" dealer as i do, and want to do business with them, see if they do what mine does. they dont "allow" test rides either, BUT, if you fill out your paper work, and buy ins, then the bike is yours for YOUR TEST RIDE. IF YOU CRASH AND BURN, its your bike!!! if you bring it back, in the same shape as you left with it, and you dont want it, THEY RIP UP YOUR PAPER WORK, and say thank you very much for considering us as your dealer!!! what they told me was this is the only way for them to be covered for a brand new bike, in case you wreck it. and if you think about it, its pretty much true!!! if you were to crash a brand new bike, on a test ride, they would have to eat the cost of repairing it, and may be responsible for your well being also, if you sued, saying the bike was faulty. so that way, they are covered on all angles! check it out and see. keep on winginit rick
I will add a little more from my previous post.
It is a big challenge for me to ride any big bike due to my size. 5'7", 135 lbs. with the wrong thinking I would be riding a 1300 vtx or smaller. I am also disable from Vietnam, Shot in the left knee that blew out my knee, no knee cap. I lost half my bicep on my left arm just to mention a few of my problems. I do not let it hold me back. I have to wear a knee brace almost always.
I am really enjoying my Goldwing. I do admit What drew me to the GW was the reverse. I have a terrible time backing larger bikes backwards. My knee will not let my leg open all the way. This cuts about 2 inches of my leg length.
I have rode my Ultra Class for 3 years and have had a blast riding it, as my wife has. Talk about heavy. My wife is limited on how she gets on the bike. She has to get on then I get on. It is then required to lift the bike off the side stand. Remember my left bicep is the size of a egg. This takes a lot of effort and sometimes it is almost too much but I make it.
The GW is a dream come true. It is so easy to get off the kick stand that there are times I almost go to far the other way.
The moral of this story is this: You are limited to what you say you are. I believe in myself and know what I can do.
I will say this any bike is fast with me on it. It doesn't know it has a rider. LOL
dd
The lowering blocks well made and would be a simple install. However, Due to lowering the GW would increase scraping. If lowered front and rear, with the kit it tells you to push the forks up or dropping the upper triple tree 1/2 inch to 5/8 inch . This will change things a lot. If you are using cruise pegs how low can 1 go before the rear tire lifts?
This would concern me. Although I am vertically challenged I have never liked lowering kits. I am scraping like crazy now, at 5,600 miles my right foot peg looks bad.
This is nothing but my opinion and we know all about that
LOL
1 - 18 of 18 Posts
