My plan was to purchase a trike, but today received a letter from Honda motorcycle support re: my request for info re: Honda warranty coverage with a trike. I was told by the trike company that Honda would honor the "Honda" and the trike company would honor the trike portion. Now I'm concerned because Honda says "Failures resulting from modifications to your Gold Wing are not covered by the Honda limited warranty." What I'm concerned about is if I have a warranty issue how can one tell if the issue was caused by the trike mod? Anyone care to comment.
It's a sensitive topic.
Some Honda dealers will look the other way on the claim and not report the bike has been converted. Mostly depends upon the dealer, now if the Honda dealer converts the Wing to a trike it may be a different situation.
Basically, here's the deal. You trike your Wing and you kiss good bye to warranty coverage on any drive train failure, if mother Honda knows it's been triked
Of more concern may be the fact that most dealers refuse to work on a triked Wing simply because they are not set up to do so.
The different case TL cited is a confusing part of the warranty, no warranty deal. We are smart enough to know that Honda knows they have dealers that are doing conversions and they know that several of the warranty claims filed are on converted Wings. Yet a "blind eye" is turned and those claims are covered.
Bottom line, you take a chance on warranty or no warranty when you convert you Wing to a trike
Cal is right. Its considersbly cheaper to buy a used bike with the conversion done. Val is also correct about dealers. If you've got a history with a particular dealer or even several and they think of you as a valued customer, they will continue to work on your non-trike issues unless the problem is obviously caused by the conversion or the installer.
The trike will add weight, putting a heavier load on the trans. If you go with a permantly mounted trike, you should get the rake kit for the forks. That changes your steering geometry. There are numerous areas where a less reputable dealer or service shop would try to blame all problems on the conversion.
As much as possible, stay with who you know and have trusted in the past.
One thing I have been told by others it is usually less expensive to buy a Trike than to get your own converted.
Cal is right. Its considerably cheaper to buy a used bike with the conversion done.
There is some truth in the above statements. One needs to be careful looking at "used units"! Some conversion dealers take used Wings, install conversions and try to sell @ just a few thousand under what a brand new converted bike would cost touting the new conversion as a justified reason for the inflated price being OK!
There are a few good installers out there that offer discounts off MSRP on these conversions. You do not have to pay full price.
They may not continue to work on your trike because many are not set up to do so! If they don't sell trikes, they are most likely not to have the lifts needed for trikes and therefore will not work on them.
The average kit will add approx. 300#'s to a Wing(give or take). Not a lot of added weight and I do not believe this is enough to induce undue stress on the Wings drive train.
If you go with a permanently mounted trike, you should get the rake kit for the forks.
Yes, to this. Rake kit a definite advantage on a trike!
Perhaps a good case for a Voyager or Tow Pac Insta Trike. It's not a permanent conversion and can be removed in a few minutes if you want to take the bike in for service work. On the Tow Pac only adds 150 pounds. They provide the stability you need at a fraction of the cost. New, cost 4-5k. Bought mine used in like new condition for 2k.
