We all know that my ass puts all of the extra weight on the rear tire. Chopin has an ass too!You also have a front tire that carries the weight????
Good point on the CT. I have never thought of it that way.That's why I ride a car tire on the rear. It gives me an additional 200 lbs more load rating than the motorcycle tire. Either lose your tire or get a better rated tire.![]()
Okay I'm sorry I have to jump in here because I see the "Car Tire Cult" got hold of this thread an although I love them they didn't really answer your question directly.GVWR, huh ?
How the heck can the GVWR of the 12 wing be 1186. The bike weights between 900 and 933 ... my 230 lbs would eat up all the remaining capacity. I dont know of many adults weighing ~125 each .. then
gear !! ??? Huh ???
I run 32 psi. in my rear Kumho car tire. At that pressure it is still 200 lbs over the load rating of a motorcycle tire. I can run mine up to 50 lbs max. But why ? Anything above 32 psi (cold ) gives my passenger a rather hard and bumpy ride. At 40 psi. she would arrive at the intersection before me.One more reason to watch your tire pressures, regardless of what skin you have on the wheel. We all carry more weight than the specs say we should and proper inflation is just one more safety factor on our side.
A car tire will not increase you're pay load max on the bike " per se ", it will only increase your bike's load weight on the tire "'per se " . Tireless bikes would not have this problem.I am not going to say anything about the CT. I have my own engineering reasons for not doing it and that's all I am going to say. It's not really the tire that limits your GVWR. It's the rear spring. With your bodies in the seats the weight is distributed front and rear, more on the rear but maybe 35% is on the front. The stock rear spring on a Wing is rated at 900# per inch. That means it takes 900# pounds to compress it one inch. The preload adjustment will move the spring aprox 14.7 mm so set at 25 (with the proper hose and bled right) that will add another 450+ pounds to move the spring that same inch So add that up and you get the max the bike should carry comfortably including the bike of course. Honda lightens that up for their own reasons. If you want, or need to carry more weight you would need the progressive rear spring that is rated at 1100# per inch. But like was stated on here many Wings are over that without issue so it's all up to the individual rider.
