This didn't seem like the right forum for problems, but it seems there are several others here, so here goes:
What I'm experiencing is this: Many times when I apply the front brake lever all the lights, to include the radio and clock cut out for a second or two. Sometimes, the clock resets to 1:00, and sometimes it doesn't. This doesn't happen every time I apply the brake, but when it doesn't, at a minimum, the lights and displays dim for a split second. Further, my reverse doesn't seem to want to work. I'll put it in reverse, and the light will light up, but when I push the start button, it moves about an inch, and stops. The light stays on, but the motor stops turning. Oh yeah, and since all this started I get that whiny engine noise through the headset.
To me, it's behaving like a bad ground would, with the lights dimming and all. But I'm not much of a whiz at electrical. Not this type, anyway. The one commonality I've found in all this is that all the problems seem to be related to the right handle bar. That's another reason I'm thinking (hoping) it's just a ground problem. I haven't experienced any problems, however, with the cruise control, which is also on the right, as you know.
This all seemed to start after I got caught out in the rain the other day. I don't know if it's a coincidence or not, but I was under the impression that the bike could tolerate a little rain.
Any suggestions would be a great help before I resort to getting scalped at the repair shop.
