Just got my '06 back from the dealer's shop. It was whining in OD, so after waiting on the Honda rep to check it out, mechanic got the OK to pull the engine apart and figure out the problem.
Turns out the OD gear had a bad spot on it that was causing the noise.
New gear was installed and it's quiet as a Honda now.
I, luckily, purchased the extended warranty when I bought it last spring. All was covered 100% except for the air filter I had them replace while it was apart.
Many thanks to Keith and the crew at Gollan's Honda in Warren, OH for a job well done!
Glad your problem was fixed. Sometimes those extended warranties are worth their weight in gold. Ride safe and quiet....
Glad to hear all is well. We sometimes scoff at ESC's when we are pinching pennies. This shows what a benefit it can be should the need arise. Did you check the cost of the repair against the purchase of the extra coverage and see what the actual savings were?
