1 - 15 of 15 Posts
I just picked up a 96 GL1500 SE today and I am going to give it a good go over since I don't know any of the service history. I am planning the following with these parts:
Timing Belt: NAPA 250275 (x2)
Thermostat: Napa 53308(Made by Stant), O-ring gasket(Honda dealer)
Coolant: Honda dealer, 4.3 QTS
Radiator hoses: Honda dealer
Rear diff: Hypoid gear oil SAE80 (4.7oz) - Synthetic good??
Clutch and Brake flush: DOT4
Oil: 3.8QTS (I use 5w40 Synthetic RotellaT6 for all of my bikes)
Spark Plugs: NGK 5129 DPRTEA-9 (.8~.9 mm .031~.035 in)
Please let me know if there are better parts to use or better place to get them or if I should take a look at anything else while I am in there. Thanks in advance!
:) Sounds like you have a good plan! You may consider flushing the micro switches @ the clutch & brake levers with some contact cleaner, they can get dirty and cause issues...hit them with some air to clean them out.:) There are a few more..depends how much you want to do..reverse & side stand switches come to mind also.
Nice looking bike. Check the condition of the brake pads and rotors.
Congrats and welcome from Central Washington.
You don't see too many that color. Ride safe and welcome to the forum..
Magenta is not common at all, they stand out somewhat IMO. Good to check, but I doubt the rotors will be an issue, Honda stock rotors are amoung the best there are.
Welcome to the GWOF. One of my riding buddys has the same color. we kid him,about it being a Barnie Bike., from the kiddies show Barnie the Purple dragon.
Nice bike.
The owners manual says that sae80 gear oil is recommended for the rear end, but I have been to a couple auto parts stores and neither have straight 80. Is something like 75w-90 or 80w-90 compatible?
I use the SAE 80w-90w Yamalube Friction Modified Gear Shaft Lube. Mag: Is Ridersville Cycle still there on 522 ? I had my eye on a Victory Vision for a awhile. It was a great place to sit on a Victory and a Wing in one showroom.
I would agree, looks new. Maybe there is a date code somewhere on it?
1 - 15 of 15 Posts
