1 - 10 of 10 Posts
I have never had any problem with my '01 GL1800 (30k miles) until this past weekend when the cruise control started acting up.
First, it would not engage with the lower button (coast). After several tries it would engage, the panel cruise light would come on and it would work normally for a few miles and then drop out for no apparent reason. Asked riders behind me and no one noticed brake lights. Am running one of the 'BackOff' flashers.
Checked clutch and brake switches and see no physical issues. Before I start tearing into the CC switch unit anyone got any obvious solutions? Searches of this and other sites produced no definative answers.
Thanks for any assistance.
TestPoint
TestPoint
I read on one of the other boards that you might want to try some of the electrical spray cleaner on the switch. If that doesn't work, you'll have to take the switch apart and clean it by hand. I recommend a service manual if you're going to do your own wrenching.
Good Luck! :)
Do you hear 1 click or 2? Next time push out just a little on the clutch lever and try to set the cruise control, then try the same thing with the front brake lever, if that works either replace the switch (about $15.00) or spray contact cleaner into it.
I have had a problem with the switch sticking on my bike, not engaging. WD-40 fixed my issues. I would spray all the cruise switches first and then see what happens.
I wouldn't use WD 40...Not good for electrical components....
Did you check your foot brake switch as well?
WD-40 tends to allow gunk to build back up. Electrical contact cleaner does not do that, in my experience. Just be sure to have a rag in your hand under whatever you're spraying to catch the drips. Paint hates contact cleaner. Lol
Wings! Wings! It's all about Wings!!
Yall use what you want. Its not usually the electrical components in the switch, its the mechanical action of the "clicker" in there. Like I said, whatever works for ya.
Reactions: Cantankerous
1 - 10 of 10 Posts
