I was thinking about buying this item for my GL1800:
http://www.kuryakyn.com/index.cfm/go/Home.ProductDetail/IMID/3769
I am concerned this trim piece will hit the windshield, or stop me from raising the front fairing piece it attaches to. The fairing piece I refer to is attached to the bike via one nut on each side near the mirrors. There is also one bolt underneath in the center that secures the metal frame. The part hinges upwards, like a car hood. I have raised mine, removed the hinge nut on each side and removed the fairing piece to replace the windshield.
Contacted Kury. They told me not to raise the fairing once their trim piece is installed, just remove it. I explained you have to raise it to remove the nut underneath in the center above the headlights.
The guy tells me this part is NOT hinged and does not unbolt as I explained. I was speechless. I explained I had replaced the windshield recently and I knew how this piece is attached. He told me he was not going to argue about it. WHAT? Who's arguing? I dropped the discussion.
He said they have sold a bunch of them and no one has complained.
Is this how all of Kury's tech support people are? I'm not impressed. Obviously the guy has no clue how the fairing piece works on a GL1800.
If you have this Kury item on your GL1800, could you tell me, is it possible to raise the fairing without the trim piece hitting the windshield?
Rob
Rob
