1 - 11 of 11 Posts
I just bought the bike and it howls from somewhere .2008 and has 27000 miles on it. Going in a straight line it howls but when doing quick back and forth banks it is even louder. I assumed it was the tire issue I keep reading about but now am thinking it is in the drive train. Did not get a manual with the bike. It was also in an accident with a deer. I saw pictures and it looked not to bad but who knows. Any ideas. Can someone tell me where the final drive oil check point is.
Thanks for any info
Bill
You can check the final drive at the rear end. There is a drain plug on the bottom and a fill hole on the top. Take the top plug out and place your finger in there should be oil on the tip of your finger if it's full.
As far as the howling, what brand of tire are you running on the Wing? Different tires create different sounds when riding in a straight line or cornering.
The tranny's are not super quiet on these bikes.Fifth gear is the quietest, thank goodness. Tires produce most of the " howling " and it doesn't take long for a new set of tire to get noisy. Put 41 psi in the front and rear tires. I have noticed this phenomenon : Riding solo with suspension setting at max. 25, the tires are noisier on the leans than a setting at 18. Final drive lube ? Looking at the final gear case at the rear wheel hub, the drain bolt is at 6 o'clock and the fill cap/ bolt is about 9 o'clock. With the bike on the center stand, remove the fill cap/ bolt and if you can get you pinkie into the hole and get some grease on it the level is fine. When you fill it , it's to the point where the grease just starts to dribble back out.
The E3's will howl on straight roads and get louder in the corners, When you put new tires on put on Bridgestones 709 front and 704 rear. If you want to correct the speedo and odometer error put a 702 on the rear it's a 70 series and will correct the error. This is the 702 after 9,000 miles on my08
Joe that's about the same wear I have on my '09 (OEM D250) at the same mileage. Tires are much more vocal in the corners than it was a couple thou earlier, but not what I'd call a howl yet. I'd bet money that buyarbi's noise is a combination of gear whine, tire song, and a slim possibility of rear diff noise. Some fresh blood in the diff won't hurt anyway.
The only grease zerks I can see are on the brake caliper. There are bearings in the drive shaft and in the housing, but I don't see any zerks for greasing them. Didn't really get into it that deep just kind of skimmed it while I had a couple moments to spare. The manual is very large and detailed so it may take some time to fully study the final drive. Check the trouble shooting page(s) of all sections that pertain to the final drive and you should gain some insight there. Honda only produced the one service manual for '06-'10 Wings so you got the right one from Wingstuff.
The gears inside the rear drive have a colour patch on the teeth (as all difs are supposed to) to tell if the teeth are aligned properly as they mesh during rotation. Unfortunately the outer case at least has to come off to inspect the wear pattern. Too much colour loss to one side or the other indicates mis-alignment or problems, but that's unlikely with a bike as new as yours, though not impossible. A good indicator is when you drain the fluid that was in it. Dark fluid (or even blackish as yours was) doesn't necessarily mean internal problems, but certainly it was time to change it. Metal filings however are a different thing altogether. YOu have likely disposed of your old fluid already, but if not, but on a surgical or mechanic's nitrile glove and dip a finger into the fluid in the bottom of the container (any particulate will settle to the bottom) and rub your finger and thumb together to see if any filings are present. If there are, you may have some excessive and un-natural wear happening.
:confused: I don't think you will find any zerks grease fittings on a brake caliper. I think what you see that looks like Zerks are really the pressure releases for bleeding the brakes. They look just like Zerks but they are hollow and allow the brake fluid to squirt out when turned CCW. The last thing you would ever want is bearing grease in your calipers. Check that out before you hook a grease gun to those. :eek:
Good call DW, I was just looking at the grainey photos on the online manual, and yes they would be the bleed valves (duh).
I just put a new set of Bridgestones on my 08 and noticed the same thing regarding wanting to flop over when turning. Mine got over it within 100 miles. I not sure if the handling changed or I got used to it, but it is not long an attention getter.
1 - 11 of 11 Posts
