21 - 23 of 23 Posts
Just giving this a bump to the OP thanks for the great work.
How would one read the codes if they are on a trike? I have no kickstand!
FI light appeared about 150 miles into a 250 mile ride in heavy rain. I notice that OD light comes on when I'm in neutral and the motor is running, too.
excellent question here: I'm all ears
Ronnie
Ronnie
You have to get to the harness that used to plug into the sidestand switch and see if the switch is still there, tucked up behind the engine side cover. If the switch is there then you just have to turn it clockwise to the down position. If the switch is not there, then there’s two wires jumpered together to make the trike start and run in gear. These two wires have to be separated and the green wire needs to be jumpered to the third wire that’s not currently connected to anything. You will know you have it right when the “S” lights up on the gauges to indicate the stand is down when you turn on the key.
21 - 23 of 23 Posts
