I inherited a '93 GL1500 from my dad which has an added switch bank over the clutch fluid reservoir that I have no idea what it goes to or does? Anyone on here familiar with what this might be or is it something that could be anything depending on what the installer chose to add?
In case it helps I have attached pics of the cover and the inside so you can see what it looks like and the color of the cables going to the switches. Cable colors going left to right are: 1st switch has red cable to the front (which daisy chains to front of every switch), orange cable on the left & green on the right (the green also daisy chains to right side of each switch), 2nd switch is black on left & green on right, 3rd switch is blue on left & green on right, and the 4th switch is yellow on the left & green on the right.
If anyone can help me figure out what these switches could go to or control and where I might pick up a replacement for the broken housing I would appreciate the help.
Thanks!
Thanks!
