1 - 3 of 3 Posts
i've had the carbs rebuilt, timing belts and ingnition pulse coil assembly replaced. Had the carbs looked at by a different tech. after the rebuild. Having issues with what seems to be a sticking float like symptom. Very sporadic. Some times works fine, especially when i bring it to a mechanic. Other times it wont get out of its own way. Low power at hwy speeds, sometimes the smell of gas. Poor gas millage. Anyone have these issues out there before?
Welcome to the forum Floyd from Pa. Sorry your first post is a problem. I'm not really a "wrench" guy, but you can bet someone will chime in here shortly with comments and a possible fix. Hope you get it fixed soon and ride safe..
Welcome from Florida Floyd.I join Two Wheel by saying sorry you are starting here with trouble.However,you have come to the right place. When i first joined i read many posts about this issue on 1500's.I hope this takes care of your problem.It sounds like your auto fuel valve is sticking and/or the diaphragm is leaking.From what i have learned here,you can either repair it or eliminate it.Many folks on here have mentioned eliminating it with no adverse effects.So,you could bypass it & see if your problem is solved,then repair it if you wish,or leave it bypassed. Let us know what happens as there are a bunch of us on here who would want to know.Good Luck with it.Ken '94SE Pearl White
1 - 3 of 3 Posts
