I received a question on how to check the fuel pump on the GL1500 and I'm going to post the test procedure from the service manual to make it easier. The diagram is for the wiring harness, where you will connect the jumper wire.
I love these manuals the test procedure never mentioned to check the strainer or the rubber hose attaching the pump to the fuel line inside the tank. this is a helpful way to insure you are getting the correct volume of fuel, but a little more investigative work is needed before shelling out cash on a pump. Thanks Trikelady
Good post, thx:D
