Well ever since I bought my 89 I have had a bit of a flat spot right off idle . A bot disturbing when going around a corner and the bike feels like it wants to lay down then suddenly it makes it way past the flat spot and takes off . I synced the carb did the seafoam and no go. I've heard about the vaccum line under the carb and am in the process of pulling the Tuperware off to inspect the lines and possibly rebuild the carbs.I'm thinking the vaccum line may be the culprit because if I have the choke on a bit the flat spot is not so pronounced. I have heard that the 89 - 90 wings had this problem and was a known issue. My question is if you find carbs for a newer wing and install them 1 - does this cure it and 2 - are they interchangable ? I also plan on replacing the timing belts as I believe they are the originals and I bought the bike from the original owner. They only have 45,000 on them but figure the time probably beat them up.
Any assistance is appreciated.
Thanks,
Chris
Thanks,
Chris
