Hello fellow Riders,
I'm having a starting problem. Bike in Neutral, switch on, but when starter button pressed, I only get a click. The battery has a full charge, and I would like to know if the Solenoid is the problem. I've heard that you can check the starter by using Jumper cables. Does anyone know how to do this? Thanks
If you're getting a click there's power going to the system. However it may not be a solid connection, check your grounds and then check the starter.
You can try jumping across the two heavy wires on the solenoid. That gives direct power to the starter.
I don't think the original poster still needs our help. He hasn't been on since 10-22-2012!
I have a 1985 gl-1200 will only run if throttle is held all the way open
carbs have been cleaned. possibly bad fuel pump
Cool...a blended thread!
"Carbs have been cleaned" is a subjective term. Cleaned really well? Including removing and cleaning the main jets and slow/idle jets? Floats and pilot screws adjusted to correct specs? I'd suspect the low/idle rpm fuel mix more than the fuel pump......
I agree with tank^^^
When the fuel pump kicked the bucket on mine, it wouldn't run without the choke on full and once the pump started getting warm it would quit all together. I'm betting on mixture in your case. Maybe a small piece of trash in your idle jets. When you cleaned the carbs did you be sure to resync them?
