1985 gl1200 spits and sputters between 2 and 3 gear but runs good otherwise. bad carb?
R rickmanning · Registered Joined Jun 13, 2011 · 1 Posts Discussion Starter • #1 • Jun 13, 2011 1985 gl1200 spits and sputters between 2 and 3 gear but runs good otherwise. bad carb?
Cantankerous · Super Moderator Joined Mar 12, 2010 · 11,936 Posts #2 • Jun 13, 2011 Hello and welcome to the forum. Sounds like you might have a bad carb. If your RPM is below 3000 it will show up more with a plugged low speed circuit.
detdrbuzzard · Super Moderator Joined Aug 21, 2008 · 15,140 Posts #3 • Jun 14, 2011 hello rick, welcome to GWOF. i see cantankerous is helping you
budoka · Administrator Joined Jul 30, 2009 · 25,938 Posts #4 • Jun 14, 2011 One other thing, check to see that the drain holes in the plug recesses are clear. Moisture build up in there often acts similarly.
