My wife recently purchased a 1987 GL1200 Aspencade with Factory Cruise Control (not after market). The Cruise On/Off button is very sticky, but if you mess with it enough the "Cruise On" light on the instrument panel will come on and go off. The Cruise Set button does not work at all. The "Cruise Set" light never comes on. I suspect these switches are in need of a good cleaning with contact cleaner and then lubricated with some dielectric grease. The GL1800 buttons are notorious for getting sticky and I have had to use the above described procedure on my '05 Reverse, Hazzards and Cruise buttons periodically.
Has anyone on here successfully cleaned the GL1200 Factory Cruise Control Buttons?
