1 - 3 of 3 Posts
GL1100 has, New timing belts, timing perfect. All valves adjusted dead on. New head gaskets and seals. Carbs rebuilt with Randaak kit very carefully. Hooked up a brand new 4 gauge carb sync today and cannot synch carbs. Has a bad knock at idle but will rev to 7000 easily.
Left side carbs 2 and 4 synch just fine about 2/3 of the way down the left side on this gauge. This is not my gauge pic by the way.
Cannot synch them to right side 1 and 4. The non adjustable carburetor #3 shows vacuum way past 2 and 4. All the way past bottom center and into the green. Number 1 carb only shows 1/3 as much vacuum as 2 and 4 and adjusted all the way in. At a complete loss on what to do here. It's like number 3 has way too much vacuum and number 1 has half what it needs.
I hope somone with way more brains than me can chime in on this. Vacuum guages and me don't get along very well.
What happens if you try hooking one of the gauges to each carb. one at a time. Make sure you are not fighting a defective gauge set.
1 - 3 of 3 Posts
