Good evening. I have a 1996 GL1500SE with some carb problems. The bike sat for 3 years. I pulled the carbs (per Jim Martino's post, great help) and cleaned them. It will start and run erratically and only with the choke all the way on. Above 4,000 RPM it runs without the choke. If you let the RPM's drop without the choke on the engine will die. Even with the choke on it will surge between 800 and 3000 rpm (that's with the idle set up all the way). When you set the idle lower, but high enough so it won't die, it still surges. I've definitly missed something. I'm taking them back off tomorrow. Any ideas about what I should look for would be greatly appreciated!
Added: Does anyone know where to find a diagram for the vac lines? My manual doesn't show. thanks again
