1 - 12 of 12 Posts
I just got a 1985 GL 1200 and she runs and rides great but I have a question about the front-end suspension. When I stop the front-end dips down may be 2 – 3 inches. When I pull out the front-end rises 2 – 3 inches. When I put her on the side stand she pushes up 3 – 4 incles and when I get off she pushes another 4+ inches. Is this normal for a GL 1200? Some additional facts – using the compressor on her I have the front and rear set at the first recommended bar.
Thanks for your help
Ron
may be time to replace fork springs and oil. i did my rear suspension last week and may start on the front if its not too hot this week
also what setting is the tract on the lower of the forks set at? the higher it is set the less dive the front will have
On my 1200 I replaced the front springs with Progressives at ust under 60k. Best thing I ever did. Kept the TRAC set on 4 when loaded for touring.
i am going to install the progressive front springs too but even with the stock springs i've never added air to the front suspension
Discussion Starter #9
Does your react like mine? "I just got a 1985 GL 1200 and she runs and rides great but I have a question about the front-end suspension. When I stop the front-end dips down may be 2 – 3 inches. When I pull out the front-end rises 2 – 3 inches. When I put her on the side stand she pushes up 3 – 4 incles and when I get off she pushes another 4+ inches. Is this normal for a GL 1200? Some additional facts – using the compressor on her I have the front and rear set at the first recommended bar."
maybe budoka can answer that for you. i replaced my rear shocks with conventional spring shocks, no air. my compressor stopped working. hopefully the progressive front springs will be heavy duty enough that i don't need air or i'll have to r/r the compressor which i'm not ready to do
Ron I have an 85 Ltd have not noticed that much dip. I am short and run no air in the front or back when I ride alone. I did change the fork setting to the #4. I did have some front trouble that I want to pass along. I had a slight slow speed wabble and I sure didn't like it. It was only at start and stop. I checked everything fooled around with air pressure and took off rotor covers. When I found the problem it was loose bolts in the fork brace. I have tighted them up a couple of times now and it sure does make a lot more stable ride. Made me feel better too!!!!!
Ron (also)
Discussion Starter #12
thanks for the feedback - I have already had my front tire off to replace the speedo gear so it is not my frontend. My next step is to change the oil. What I have found out is the anti-dive setings have more effect on the frontend than the air. If you put 3 bars of air in the fronend and setting of 1 the frontend recoils up .5 incles more than if you had a setting of 4 and no air. If I add air and setting of 4 I get a .75 incles less recoil. I think the oil makes the difference. So my next step is Amsoil Shock Therpy (#10 Weight) in the front forks. Again tanks for the feedback
Ron (too)
1 - 12 of 12 Posts
