Hi everyone.
I'm a newbie to these forums and Goldwing ownership. Bought an 86 Aspencade back on December 23rd, it was running fine for about 600 miles, but the day before yesterday started running rough. Initially there was a small amount of back firing, then on the odd occassion was hard to start when warm. Then the other day dropped down to 3 cylinders. Initially I replaced all 4 spark plugs, have great spark, so the fault does not appear electrical. Then with the help of a friend, we pulled the carbs out and they were all clean inside (actually a lot cleaner than I expected that would be), although the air filter needs replacing (have ordered another one from eBay)
So upon getting it all back together, it still ran the same, but then started flooding fuel out from the canister (that thing just to the rear of the fuel pump). We've tripple checked all the vacuum routing, everything appears to be correct.
It also appears to be dumping a lot of unburnt fuel into the exhaust which explains the back firing.
Any thoughts?
Any help would be greatly appreciated.
Any thoughts?
