Heading out of the country. Will be monitoring any responses when I can. Going to be quite remote
for a few weeks.
Thanks,
Corventure Dave
for a few weeks.
Thanks,
Corventure Dave
A quick way to adjust this is to have engine warmed up and engine on. Start turning the barrel out until the idle starts to rise, then back off until it's at normal idle.This is where the adjuster is located. You wll have to pull the paltci piece out of the wya to get to it. Loosen the lock nut and turn the barrel about 1 1/2 - 2 turns.
If you get it too tight it will accelerate when you hit the cruise. Trial and error.
I’d be questioning the speed sensor, from what you wrote. I’d be looking for the test procedure on it. Well, if you could test all input sensors from the cruise module, that would help too!Appreciate the reply's, however...
My issue is "not" a lag in adjustment. I'm experienced with this as my 2005 had this and I needed to adjust it to correct.
My issue is that the engine rev's up dramatically, 1500+ rpm when I engage the cruise, then cuts off the cruise.
I'm presently tearing into it and removing plastic.
The bike is completely rideable. I'm looking for some possible electrical disconnect, relay or cable issues. Worst case I may have to just try replacing the cruise control module, $300+ part!!!
As I stated before, this just started to happen after 16,000+ flawless miles.
Corventure Dave
