1 - 2 of 2 Posts
Here is how I changed my oil for the first time '95 Aspy 27K;
Remove saddle bag, drain old oil after loosing refill plug; top plug.
Insert nozzel of new oil container in refill hole, there will enough space and watch indicaters on side of container to make sure you refill with the correct amount, ie not air trapped. I just refilled till it overflowed; a little messy.
Tip you can use a pump oil can, less mess.
No need to remove the saddlebag. Use an old style oil can or you can buy a pump that screws onto the top of the gear oil contaimer. I change my final drive fluid every other oil change.
1 - 2 of 2 Posts
