Actually, it appears I can use a prelude pump-which is 62 bucks new. I had to order it-will be in Monday. I'll post how it works...the specs in my Aspy book say 2-3 lbs of pressure and the prelude pump specs at 1 1/2 - 3 1/2 lbs. Which should be good enough? The fuel lines are the same size and locaion. The rubber isolater and bracket from the bike will fit right on. The only bad part is that it is not chromed - but that can be fixed as well.....
what year is the prelude you ordered the pump for
