I have a '94 GL 1500. It has been leaking fuel on the left side. I finally got around to doing a little digging, and it seems to be coming from the carbs. Is this a carb rebuild, gasket?
Yes, you can rebuild the carbs.
The gaskets come as a kit.
And while you have the carbs off look ffor any sign of coolant leaks. If you find any replace the part. Check all hoses and tubes to make sure there is no sign of hard or brittle lines.
I grew up in a Triumph/ Yamaha shop. I allways felt Honda loved to bury everything and the Goldwing is the prime example of this. With that said, it just takes longeer to work on a Goldwing. You MUST have a good shop manual, The proper tools and a good torque wrench. Take your time and read the instructions well.
