If I remember right,this is just a 2 beer project.
You need a #2 phillips and a 8 mm socket.
1 pull back the rubber boot (rubber is tough and you will have to wrestle it to see and remove 3 screws to take off the side mirrors.
2 flip up the windshield levers.
3 Remove the 2 screws, one one each at the side mirror to remove the big front chrome cover (across the front of the bike) this exposes the screws to remove vent tube.
Pop out the 2 vents and then a screw (from the front) to remove the vent tube.
Look before you do it, but thinking you need to take off the windshield here to expose the lip of the dash as well.
At this point, I can't remember how much of the tubberware has to come off around the handlebars but this much will get you close. Key ring first, center panel and then surrounding plastic.
We are happy to help here but will say a service manual is priceless if you plan on doing much more like this. It is better with pictures.
Good luck and welcome to the forum
