Hi, I am a new Goldwing owner. I purchased an 84 Aspencade with a voyager trike kit two days ago. I am trying to get it to pass MO safety inspection but the brake lights don't work when using the front brake handle. They do work with the back brakes so I know it's not the bulbs, fuse, etc. I tried taking the switch off and connecting the two wires with a paper clip, no luck! So if it still doesn't work what else should I look for? I am dying to get my bike licensed and hit the road!!
First of all, welcome.
I would trace the wires and make sure they are all in good condition.
I would check the wires to the switch at the brake lever. I have heard of them coming loose.
Discussion Starter · #4 ·
Checked those wires, they all look good.
Thanks! I was hoping not to have to trace the whole path of the wires, but I guess that is next. Thanks
If you removed the connection from the switch and jumped it with a paper clip and nothing happened, you may have no power or ground at the front brake light circuit.
If you have a test light check to see if there is power going to the switch.
The micro switch is near the reservoir and the wires come from it.
It is part number 35340-MA5-671 SWITCH ASSY., FR. STOP
This picture should help. It is part #2
