I cannot find anywhere in the manual the replacement bulbs for my bike...it's an '07 GL1800 lev 3. appreciate any help.
btw...is it difficult to replace?
thanks in advance
Thanks for the info
Appreciate the website...I had found that one, but still cannot locate the proper bulb for the fog lights. I did, however, find them at Wingstuff...only thing I need to determine now is if I can replace them with 55W bulbs rather than the 35W bulbs that are presently on the bike????
Don't quote me on this yet, but I have heard that increasing the bulb watt may require a harness modification. I mention this because a local ( to me ) '06 rider is trying to interest me in buying an extra fog light set he has and that all the wiring is there to use a 55watt bulb. I can call him anytime, I'll just post this as a caveat until we know the facts.
Guys here's the skinny on wattage & wiring.
Watts divide Volts = Amps..... Sooooooo.
35/12(to be safe) it's actually hire = 2.92 amps
55/12 = 4.58 amps
I doubt that the wiring is any issue unless it is less than #16 guage wire (which I highly doubt). You may need to check the light socket or the Lens housing to just be sure they are not only rated for 35 watts. Again I doubt that's the case. I think you will be fine. Both of you.
Again this is just One Ole Fossil's Opinion.
Discussion Starter · #7 ·
Got'em
checked with the dealer this morning...apparently the 55W are suitable for the GL1800...bought a pair and on my way out to replace the old ones. Thank you all for your input.
