My book was downloaded and printed, and there's not enough resolution in the picture of the float level, where it says .61 inch or 15.5 mm. Measured where? The float is sort of rounded. Is this possible to do w/o the tool, indicated as H/C 023892 or p/n 07401-0010000? P/O apparently had these carbs apart before, I saw cement on the float bowl gaskets, one of the pilot idle screws left its point stuck in the carb body, and on each of two of the carbs, one of the indexing collars broke off in the body when I took off the bowl. Gasket cement on one of them too, the other broken piece missing entirely. I think the gasket should still hold OK. (I think I'm in over my head)
Discussion Starter #2
hmmmmm. I waited a while to see if any further posts came up to clarify. Do not kapische 'matting surface'. I saw reference to a $40 book with pictures so I'm going to order that. Like another owner says, it's a real pita to get these things out, and I dont' want to screw them up and do it over. Ive had them apart so long I'm really getting confused about how to get them back on with linkages. It looks like I've got some extra O-rings, so I'm getting my tit in a wringer as we say back on the farm.
Donaldo88 I'm trying to be helpful here, but it seems to me that you might have more serious problems after you get the carbs installed if you don't address the idle jet problem and the gaskets. Why not order carb kits? This is from experience, many times I've rushed a carb job only to have to remove to carbs allover again and then to take them apart again.
This site may help you get started in your search for carb kits: http://www.motorcyclecarbs.com/index.cfm
Hi there ...If the float level is correct the distance between the uppermost edge of the floats and the flange of the mixing chamber body will be 15.5 mm (0.61 in). Adjustments are made by bending the float assembly tang (Tongue) which engages with the float tip, in the direction required'
Hope that help you out
Ranger
