Did the first oil change on my new-to-me Wing and I can't believe how easy it was to do on these bikes. Now from a video I watched on changing the air filter, that might be a different animal! ;)
Changing the oil is pretty simple but the air filter is a little more involved. Steve Sanders Gold Wing forum has a video for it. It took me 3 hrs to do it. It really isn't too bad at all.
On the air filter just know what you took off last and yes the Steve Sanders video is great, my first time to do the air filter took me about 3 hours, a great winter in the garage job.
On the oil change, once you've done it, it takes about 15 minutes from then on. Easy to do.
Oil Change is a breeze. Don't forget to change the fluid in you final drive....
AS with mosat things on a the GL1800, it's the apprehension rather than the doing that's the worst. Although I will say cutting my seat open for the Utopia made my stomach roll a mite!
Discussion Starter · #8 ·
Reminds me of when I installed the top rails on the hard side bags on last bike, a '01 Nomad. I can't tell you how many times I measured for those holes before I actually drilled through those bags! :eek:
