1 - 3 of 3 Posts
So my fan switch is toast. Looked up oem number and had Napa order that part number. When I received fan switch it looked identical but the threads are small!! It fits down in housing and isn’t close. I’m thinking it needs to be an 18mm but all I find is 16mm. And most sites don’t even post the thread size. Any help wld be appreciated. Where to order what to order any help is needed
1. You do not say what it is you are working on so there is no way anyone can interpret what it is you need.
2. If you order an original equipment part from the manufacturer, you can't go wrong. Ordering from any other source but the manufacturer and you are at their mercy. Return what you received and try ordering again from the manufacturer of the equipment you are working on.
Without more information about your particular piece of equipment, you are pretty much on your own.
Go to Ronnie's Mail Order.com for your Goldwing parts.
1 - 3 of 3 Posts
