When I got the Green Wing I took her into a shop in Conroe TX to fix a coolant leak. Found out it was the O rings in the thermostat housing. Told them to replace all cooling lines, put floor boards on her, run the wire to the gps from the acc. terminal and do a 4000 mile service. He gave me an estimate of $1500.00.
1. They had to tear it down 3 times due to coolant leaks. (Didn't know how to size an O ring.)
2. Put the floor boards on and didn't use the proper bolts so they fell off in a few miles.
3. Wired the GPS tdirectly to the battery so I had to shut it off manually.
4. Didn't bleed the air out of the cooling system.
5. Told me there was a pipe plug in the oil drain so they just put it back in instead of useing an over size tapping drain plug. ($6.00 item) knowing the taperd pipe plug can split the case. I got her from my Son who said that the last time he changed the oil there was a oem plug in it and he used a new crush washer.
6. I varified the $1500.00 the day before but when I went to pick it up he tried to charge me $3200.00. He got 1500.00.
