Is ethanol bad for these bikes I must of missed that thread???
Yes, expecially if it's in older machines.
That ethonal is a killer to bikes. You will not get the peformance or the fuel mileage that you would if you run pure ( ethonol-free) fuel.
The ONLY reason, THE ONLY REASON I will put in my vehicles, bikes, engines, is if I am in a bad position and HAVE TO get it. And then, just enough to get me to a ethonal free station. Very lucky here, there is a station one mile from my home, and nine miles to the west, and four miles to the east that carries ethonal-free fuel. Cost is the same as it is anywhere else that sells ethonal.
IF YOU RUN ethonal, I would advise to run Sea Foam threw your machines to clean.
Do not full you machines up with ethonal fuel and let sit up for any time, if so, you have just signed the death warrant for the carberator of that engine. I have seen the " green slime crud " that builds up in the carbs, not counting what it eats up inside these machine that we have paid dearly for.
To show one how bad ethonal fuel is. Fill up a glass jug, something you can see threw. Best to do it with a pickle jar. Set on shelf for up to 60-90 days. DON'T TOUCH IT, JUST VIEW. Start watching close for about the third week, you will start seeing a horrible sight show up, still leaving it alone, viewing only, watch what the fuel turns into.
It will make you sick to see what you are trying to run in you vehicle.
Don't let this ethenol fuel sit in your vehicles or gas tanks. Burn it out or drain it out if it has to be set up for any amount of time. Stabil in your fuels help much for stablizing it.
Ethanol has cost a many of folks big buck around here.
