I have a 2008 gl1800 and it has developed a skipping problem. It seems that it is not getting the required fuel to run smooth. I throttle it and it hesitates then gets a burst of fuel and then goes. I have changed the plugs and added seafoam for a few tanks but still keeps on skipping. Will change the fuel filter next. Any other suggestions.
Thanks
The fuel filter might be your problem.
You could have a defective throttle position sensor.
There are several things on a fuel injected system that can cause your symptom.
Howdy kingpin08. Ditto on what cantankerous said. Might need a trip to the dealership and the laptop diagnosis if the filter doesn't cure it.
Check the easy stuff
- Spark plugs are torqued down and ignitor coil are properly seated - two plugs were not tightened from the factory and one igniter coil was not pressed all the way in. This was the cause of the symptom you are describing
the 1800 does NOT have a fuel filter, there is a screen on the fuel pump but that is in the fuel tank.
Did you try an ecm reset? Try it first.
Disconnect the battery for a few minutes, then hook it back up & start the wing. Do NOT touch anything....throttle nothing.....let it idle till the fans come on. then cut it off & restart & see if that didn't fix it.
Mark
Doesn't matter you're another moron that will never come back!
