Hey everyone, it's my first post here, just got my first goldwing yesterday. It's an 86 gl1200 aspencade and it's in great cosmetic condition. Anyway, I'm having an issue with it. I bought it not running and the guy said the timing belts were loose and needed to be replaced so I started getting into fixing them. But as I went to turn the motor over to get it to TDC the motor wouldn't budge. That scared me so I tried to turn it the opposite direction and I was able to turn the crank about a quarter turn or so just fine before the motor suddenly stopped again. I'm able to spin the motor forward and backward for that quarter turn but no more than that. I pulled the timing belts off and the left side belt was completely burnt up so I started thinking a valve could have hit the piston, bent, and is now preventing the motor from moving, so I pulled the head off the left side of the motor and everything looks perfectly fine. So I'm at a loss. Should I pull the other side's head and check that out? Or what could be causing my engine to lock up the way it is?
