1 - 2 of 2 Posts
I am new to biking and bought myself an 83 Aspencade. Been getting things fixed as I go, but I have a question. The front turn signal works fine but the back one quit. When I put the signal on, it just flashes quickly on the signal indicator on the dash. I changed the fuse and the bulb, and it still doesn't work. Any idea where I should look next?
Check your ground for the rear bulb. Then see if you are getting any voltage there. If you have a good ground,and you have voltage there,but won't light the bulb,then you have a bad connection somewhere that's not letting enough amperage get to the bulb to light it,or the ground is not good enough to flow the current needed. Hope this helps.
1 - 2 of 2 Posts
