I have a 1997 GL1500 Goldwing.
The problem is; I'm getting 12 volts from the two pin connector to Starter relay switch "B", which intern is providing power to the starter motor. This is while I have the ignition "off".
Because I've been having this problem with the starter motor continuously running after I release the starter button, and then goes away and comes back, I've replace the Stater relay switch "B" and tested the Stater relay switch "A" (fuse good, all connections good and tests perfect. Now, after the last start up, I could not get the starter motor to stop until I disconnected the batter. I've turned the kill switch off and on and didn't stop the starter motor. I've turned the ignition switch completely off and lock the forks and the starter motor continued to run.
I checked the following:
Relay 3 good
Relay 8 good
Fuse 12 good
Reverse diode assembly good
reverse relay switch good
reverse lever switch good
Starter relay switch "B" (1st one bad) (new one installed and tested)
Starter relay switch "A" Tests good even put a new one on and still 12 volts to relay "B")
Replace fuse "B" (hidden above batter box)
I have tested the starter switch and seems to be working properly at testing time.
I want to emphasize that I'm getting 12 volts continuously thew the yellow/red wire from the two pin connector leading to the starter relay switch "B". Because of this voltage, the starter is engaged. And even when I turn the ignition switch in all positions, (even off) I still get voltage to the starter relay "B".
Now, I believe its the ignition switch itself, but how to I test it before I take it out?
What else can I check, test or replace?
Still not ready to give up on the old girl.
Bruce
Relay 3 good
Relay 8 good
Fuse 12 good
Bruce
