Thanks for the kind greetings from the new member thread!
Thought I would start a new thread for this. I have a basket of electrical issues. They don’t add up to a definitive answer for me, due to my inexperience with this motorcycle. However, I would not be surprised if several here knew exactly what I need to fix. Thought I would seek wisdom before I started chasing things with a multi-meter.
Symptoms:
1) Radio does not work. None of the audio system functions.
2) Clock resets to 1:00 every time I turn off the bike and restart. If I reset it, it functions properly until I turn it off.
3) Keyfob does not work. It did when I first got the bike
4) I cannot reprogram the “Opening Ceremony”. I have carefully followed the steps in the owners manual, but it does not behave like the manual says it will. I never get to the option that allows me to change it. I currently have it turned off.
5) I have no problem starting or operating the bike. Lights are bright; spins over quickly and starts immediately. No operational issues at all, except these odd electrical items
6) Battery is an AGM unit. Have not done any testing yet. Bike was idle for some time before I bought it. I know the AGM batteries can be quirky if not used regularly or disconnected
7) All fuses seem to be in good order.
8) All lights, heaters working normally.
9) I have not disconnected the battery yet. I understand this can provide a helpful computer reset sometimes.
Thanks in advance!
Symptoms:
Thanks in advance!
