1 - 12 of 12 Posts
The wife and I went to the district rally in Rogers Arkansas for GWRRA this weekend. While on the "parade of lights" ride in downtown Rogers my handlebars started kicking back and forth. We creeped back to the motel so I could check it out. On the right sidewall, of the Factory rear tire, a bulge was forming. The next morning I slowly made my way to Heartland Honda (the local dealer). Even though the factory Dunlop tire had 7,000 miles on it, it was replaced with an Elite 3 at NO CHARGE. I asked the service man about it, and it had been cleared with Dunlop on the 3 previous ones they had seen. Mine was the 2nd rear and they had had 2 fronts also. Has Dun-floppy been doing their best to keep this quiet to avoid a re-call?:rolleyes:
I don't know the motive behind Dunlop's replacement policy, but it certainly is good customer service to do so at their expense. Perhaps they are taking the tires back and examining them for possible defects. Glad you and your wife are safe and now have a new tire. Ride safe..
I used to run dunflops all the time, the last 3 sets seem like they were very bad as far as wear and front end wobble. My last set I put on are Bridge stones. 709 front and 702 read (702 is a 70 series) 704 is stock size for the rear, and I love them so far. The 70 series will make your speedo right on (according to my GPS) and will take care of the 4 miles per 100 your odometer adds on with the stock size rear tire.
Keep your eye on that 70 series rear tire. Taller sidewalls mean more cupping. I used to run 70 series Rear tires. Tried a Metzler, an Avon, and a Bridgestone. The one I got the most miles out of was the Avon it developed a bulge at 6500 miles. The Metzler lasted 5000 miles (badly cupped) and the Bridgestone 702 went 4300 miles badly cupped). The speedo/odometer correction was great and the reduced rpms was good as well. Just keep a close eye on those 70 series tires on the 1800.
That's a great heads up 3rdwing. I'm going to pass that around our area and chapter members.
I can't wait to get rid of those Dunlops on mine! They are noisy (Sounds like bearings are gone) and hard! I had Bridgestone on my last bike (3 times) and I just loved them. They stick to the road and are quiet too. Ok .... 8000 max out of the rear tire but who cares as long as you are having fun!
Just clicked 4000 miles and the rear tire is completely bald, there is not a groove to be found anywhere. I will try the Elite 3 in 70 series to see how that goes. Is there anything wrong with keeping the stock front tire for now.
had same problem
3 years ago in searing heat my Dunlop EIII rear tire developed the exact same kind of sidewall bump you described. I was up the I-5 in central California and it was a sunday with no cycle shop of any type open. I stayed overnight at a motel and the next morning crept at 50 mph to the nearest place I could find to get new rubber, but the tire exploded like a cannon shot after a couple of miles. I thought it was the extreme heat that caused the "anyuerism" of the sidewall, but after reading this thread I do believe they have a sidewall defect issue.
Just what I have been told by people who know WAY more than myself, and it could be BS, however I have been told that your front and rear should be a match pair or they will wear more. It doesnt make sense to me but then again there are tons of things that dont make sense to me that are still right. I have never had good luck with Dunlap tires. Contenital or Metezlers have treated me best.
I've done different front rear combinations on my bikes with no ill effects so far. The tires have always been the same brand and radial/radial or bias/bias. I believe mixing bias/radial is the big no no. The main goal is to see how the 70 series tires (taller tire, more ground clearance) does for my handling as I am scraping the lower cowling on turns with slight g-outs. I also plan on getting firmer fork springs but am not looking forward to taking the new wing apart yet.
tires
I HAVE TRIED DUNLOP,YOKOHAMA.AND BRIDGESTONE.I NEVER GET MUCH MOR THAN 5000 MILES OUT OF REAR.WINGS ARE HEAVY ASS BIKES YOU RIDE YOU USE RUBBER.ESPECIALLY WHEN THE BACK HO IS ON BOARD.I DON'T CHANGE THE FRONT UNTIL IT'S READY BECAUSE IT'S 2 TO 1. ASLONG AS IT'S BALANCED IT WILL BE FINE:cool:
1 - 12 of 12 Posts
