A while back I posted that my 1997 GL1500SE engine was stalling when I went up a long, steep grade and the motor was under stress. The bike ran great the rest of the time. Many of you gave me good suggestions on where to look. I finally found a grade about an hour from home where I could recreate the scenario and the engine would stall. I replaced the fuel filter and fiddled with the gas cap and there was no positive effect. I finally bypassed the auto fuel shutoff valve and the bike ran great without stalling. I purchased a MightyVac vacuum gauge and hooked it up to the auto shutoff valve as shown in the repair manual. I could not get a vacuum to show on the gauge. I removed the valve and disassembled it and found a large rip in the outer perimeter of the diaphram. I have searched all over for a rebuild kit, but they are obviously a discontinued item and unavailable. I don't want to spend the $125 for a new valve and will continue to ride with it bypassed. It seems that my only risk is if I leave the key on and fuel pump energized it could flood the bike if the carb float seats don't hold. The chance that a siphon effect from the fuel tank through the carbs seems very unlikely. I wanted to thank everyone for their suggestions and for helping me diagnos this problem.
I remember your previous post, Glad that you nailed it down. I have heard that some guys bypass them as you have & leave them that way. Do what's right for you & all should work out.
Thanks for sharing your story hopefully it will help someone else.
Ride Safe.
Way to go. Persistance payed off. Glad you found your problem and can now enjoy riding your Wing.
