1 - 2 of 2 Posts
GoldDigger, the plastic has to come off! I'm sure there are some really specific instructions, but you will need to remove the front lower cowl, and each side of the lower fairing to get to the plugs. There are 3 screws to remove the lower front cowl, it interlocks with the panel above and each lower side fairing panel. There is a teardrop shaped piece below the lower vents, pop it loose to expose the screw, then remove the black plastic pieces on either side of the fairing reflector to get to those screws.
Reactions: Limpy45
1 - 2 of 2 Posts
