Pulled in the driveway and switched it off. Went to start and nothing. Turn the key to ACC and the clock ,radio,4 way flashers and CB work. Turn to ON and nothing works. No neutral or oil light comes on. I have checked all fuses with an ammeter including the 2 main fuses next to the battery.
All fuses are OK. The battery is good.
hello and welcome to GWOF biker boy. hows the battery? cables clean? check the battery cables to make sure they're tight and the ground wire too
First, welcome to the forum from Pa. Just a dumb question, but did you check the kill switch?? If you checked the fuses and the battery has been checked then it's probably like the Doc said, a connection problem or perhaps the ignition. Make sure everything is tight. Hope you get her fixed so you can get out and ride. Ride safe and enjoy the forum..
Probably something silly, like in gear withthe side stand down or the side stand switch, something along that line.
Is the reverse lever all the way down?
I believe there is an ignition relay behind the left side cover under the seat with the fuse panel. Check all the fuses and relays in that fuse/relay panel.
Discussion Starter · #7 ·
Yes it was the ignition/tailight relay. Pulled out the air compressor relay and used it for the ignition relay. Started right up. Thanks.
