I'm trying to help a friend with his 1988 1500. It seems like it is runing on 4 or 5 - more noticable at idle. It stumbles bad on take off and acceleration. At first is was thinking carb. problems, but after riding it for a while, it seems to do it most of the time - hign or low rpms. I checked as many vacuum lines that i could reach and all are good. I would like to do a compression check, but it shure looks like a big job. What do I have to remove to do the compression test? If I do end up going into the carbs any suggestions? What about timing belts? Could one be getting bad and runing loose. What is the procedure for troubleshooting?
Thanks for any help
Thanks for any help
