1 - 20 of 29 Posts
Just wondering how common is road debris damge to the (radiator) expansion tank on an 1800 ?
We have done 10,500 on our 1800 and recently suffered a punctured expansion tank. Whilst it's not big deal to repair, or should I say to have repaired by the local Plastic Welders .... I'm just wondering how common a problem it is ?
Appreciate your comments.
PS: We have ordered an engine plate !
Cheers:)
Seams to be a common thing for the 1800's....need to install a "belly pan"....
Oh I see where you have one ordered.....good job!!! That should fix the problem..
i heard about this and i also was thinking about getting a belly pan
I don't know the percentage of tanks that have been damaged, but knowing the amount of debris that can be thrown back off the front wheel from the road I think a belly pan is a good investment.
This one of those things, that makes me say; What were they ( Honda Engineers) Thinking. With all the Wiz, Bang, Wizardry, they put on the 1800 (ABS,GPS,Heated seats,XM radio, trunk not latched warning,ect.) How could they miss something so critical yet so inexpensive to fit, And let it continue without a service bulletin to fix it.
Just wondering
From the Northwest Corner
Ron
Discussion Starter · #7 ·
Just wondering
Ron
I'm in full agreement. Blind Freddy could see that the tank is in the firing line and needs protecting.
:confused:
It's one of the nits and picks I'm going to bring up with the gurus at my meeting next week. A couple of the guys I talk to are very receptive to input if you treat them decent and don't get all belligerent towards them or the "mother" company. Imagine catching more bees with honey vs. vinegar:rolleyes:
Discussion Starter · #9 ·
Ironiacally, about 2 weeks before we sustained the damage, I had fitted a mudguard extension because I got fed up with the crap being deposited over the front engine cover. It would have been fair to assume (arhhh, assume = 1st mistake !) that would have offered some additional protection to the crankcase & Exp tank area. :mad::rolleyes:
now you assume what ever punched the hole in the expansion tank was thrown back by the front wheel. Not very likely. The only time I hit mine was driving out of the toy hauler. That impact pulled it down and reshaped it a bit but still did not make it leak.
Discussion Starter · #11 ·
Whatever caused the damage was thrown up from somewhere. It definately was not from "bellying out" on anything. The location & type of damge show that to be the case. No question about it.
Is the belly pan strong enough to hold up most of the weight of the bike on a hard bump? So far the only problem I have had with mine involved an extra high speed bump in a McDonalds parking lot which I saw coming and crawled over it, but the bike still got a hard jolt when it came down on the bump. Did not have a belly pan, was riding 2 up and fully loaded on a long trip, the coolant overflow tank got scraped but not punctured or torn. Wondering how a pan could have helped in this situation, or maybe made bad matters worse?
Someone with a pan can answer this. Since the pan is just sheet metal, would it not compound the problem I had by getting pushed up hard against the coolant tank??
An extra layer of just about anything is better protection than wide open to contact. Having said that, you should never treat a belly pan as a skid plate because it ISN'T one. The pan is light weight aluminum, and a Wing is a big heavy bike without us or payload. Best to avoid curbs and obstacles rather than hope or depend on one.
Discussion Starter · #15 ·
:mad: I am still amazed that Mr Honda would produce a machine with such a vulnerable component location. Normally I respect Honda for having all the bases covered and, as previously mentioned, the addition of some sort of protection would be a simple & relatively in-expensive improvement.
Years ago we didn't have exp. tanks and it's no big deal to ride around without one now. However, checking the radiator coolant level on an airbag model with Air Wings is not really something I want to have to do every morning ! :eek:
Discussion Starter · #17 ·
A belly pan was one of the first addy's I installed. Not a ding on it yet. It must be working.
Just fitted mine this arvo. It's the "plain type" with a vented removable front section which is secured with 3 self tappers. mmmmm Not that impressed with the fit, but it's OK and will definately offer protection. Not mention peace of mind.
All is good :)
PS: I recently lashed out and bought an air operated m/c bench. Absolute luxury, a total indulgence, but then what's a Goldwing anyway ?? The bench is a SAM from Handy Industries in the US & I can thoroughly recommend it. Very well engineered & built .... I am impressed, plus now I don't have to grovel around on the ground !
The purchase was easily justified as I called it an "Ironing Board" ;):rolleyes:
All is good :)
I have the same " plain " belly pan. Me riding buddy has the fancy louvered style and his is beat to hell. I think mine cost about $30 ( previously owned ) and his was around $60. Now his looks like a $5 piece of scrap metal.
Discussion Starter · #19 · (Edited)
Chopin, I paid about USD$38 for mine, the louvered style was more like $68. Plus the company that supplies the latter will only freight to Australia via FedEx, whereas I was able to have mine freighted USPS. Makes a helluva difference to the bottom line ! Generally there is only a few days diffrence in delivery time. With USPS the consignment will generally arrive in Oz in about the same time as FedEx, but then it slows down. 7 days from US to Oz, 7 days from Eastern states to WA delivery. It is well worth the wait though what with your pricing & our exchange rate....... :):D
Chopin, With USPS the consignment will generally arrive in Oz in about the same time as FedEx, but then it slows down. 7 days from US to Oz, 7 days from Eastern states to WA delivery. It is well worth the wait though what with your pricing & our exchange rate....... :):D
A month ago I shipped some peg extensions up to " budoka " in Alberta, Canada via USPS. A few weeks (?) went by and still no delivery. The day before I was going to inquire with USPS the package arrived. Patience is definitely a virtue when it comes to the USPS. Sorry about the exchange rate. Convince your government to hype up the value of your currency like we do.
1 - 20 of 29 Posts
