1 - 2 of 2 Posts
Has anyone else attempted putting custom rotors and wheels on an ABS? How did you solve the problem of mounting the ABS sensing ring on the right side of the new right front rotor? All ideas will be welcomed and appreciated right up to the moment I plug in the drill to put three new holes on the inner most carrier ring. Thank you.
Sounds scary troy, um to me anyway. I'd talk to a well sesoned motorcycle (Honda) tech first to be sure. If that doesn't give you any solid help, try Stu at Wingworld's "Workbench" column. if you are a GWRRA member. Stu is a long time Wing guru and very knowledgeable. He's helped me out several times.
1 - 2 of 2 Posts
