1 - 2 of 2 Posts
OK folks. Here's the deal. The CC and Rev switches on my '03 will not engage. I push them in but they pop right out. It's like the catch has worn away. Only 28 K miles on the bike. I haven't used 'em that much. Any thoughts?
Strange symptom. Usually, you hear the opposite. The switches get stuck in the depressed position.
I'd try the same solution for a stuck (depressed) switch. Get a can of 'Tuner Cleaner'. Radio Shack carries it. Make sure you use the small tube the can comes with to get passed the housing and soak the inside of the switch housing. Then keep pressing the button to work the cleaner thoroughly. Once the switch is working again, I follow with a shot of silicon. I hope this helps.
1 - 2 of 2 Posts
