As vptech2 said, you can unscrew the cruise control adjustment barrel out 3 1/2 turns. This is a good average setting and will work beautifully in 99% of Goldwings. An alternative method is to start your bike before making any adjustment. Then unscrew the barrel until the RPMs just begin to increase. Then turn it back the other way just far enough til the RPMs return to normal. Lock it down, button her up and you're good to go.
Great info guys, thanks a million.
Thanks for the lesson on the cruise control adjustment...:)
Now only one thing...could you not have been a week earlier on the information...:D...I just had everything off of my bike to install the wiring for the CB radio....:eek:
Thanks...For the info....
Safe Ride
When you use the way wingleader09 said make sure your bike is at normal idle (warm) before making the adjustment.
