1 - 1 of 1 Posts
This is long winded but here goes. My Cruise will not set orange light is on. New master switch (on handlebar) renewed last year as well as front and rear brake switches and clutch. ECU was replaced under recall in 2005. Honda UK say that Modulator may be faulty changed it but no difference. Rev/Tachometer is not working my mechanic told me that the Actuator assembly has an open circuit. Bought one on E Bay came off a 2007 bike looks the same. These were fitted from 2003 bikes with last 3 digits part numbers differing.from mine which is 003. Fitted Actuator which has a cable with nipple like my original. Cruise still not working or Tacho. Checked throttle electric switch near left hand radiator OK. Tacho still not working. Exploded diagram in parts manual say that my model has to be purchased complete with Tacho/Speedo/Fuel and Temp Gauges, lot of money. Where can I get a Tacho that will fit and the final ??? Will my Cruise Control only work if the Tacho works. Phew!!!!!!!
1 - 1 of 1 Posts
