I have a 1998 Goldwing 1500A. Ran fine until yesterday. Bike will not start normally now. If I jump the fuel pump off the battery it starts and runs fine. If I disconnect the jumper the bike will run out of fuel and not restart normally. I have no power at the fuel pump connector (black/blue wire). I am assuming the ECU went bad. I performed the test the manual shows for the wire. Should have approx. 6 ohms. I have 6.6 ohms so I guess that wire is good. All fuses are good, tested with a light. I don't see a relay in the circuit for the fuel pump so I am leaning toward the ECU. Very expensive so looking for opinions or confirmation. Any suggestions???
